VERY bad quality...
3 replies · 1,938 views · Started 25 March 2003
I am using the hipc cam program for unlimited recording of video and when i use the real player to see it i get really bad quality!Half green screen ,large pixels!!In hantro when i try to do it..i get error message.anyone?...thanks
Hi, By the sounds of it you are using Hipcam at it's highest recording setting. In this setup I also noticed a lack of quality, even in the recording window on the phone, it was very jerky and pixelly. Try lowering the resolution and recording quality to see if that makes any difference.
As for the error, you need to use Hantro V3.3 or above to view the Hipcam files as they are 3GGP instead of the earlier Hantro MPEG4 file format. Having said that Hipcam was specific to the 3650 and should play ok without any other software.
This might account for your error as the file type is not supported
All this is from my experience with a 7650, Hipcam being a major point as I brought it when it first came out but without a 3650 and it's dedicated built in player I could not view the recordings without Wind MMS or now Hantro 3.4 from Nokia.
i updated the hantro version..with 3650 one..with sound.Now when i record in hip cam i cant even c it using real player..and when i try hantro i ger error message.!!Dont know really!! :-? ..thanks
