Info on: Changing Product Code/N8 product Codes
28 replies · 131,578 views · Started 25 October 2010
Just so I don't get screwed by Orange's inability to get updates out, anyone know how to change the product code yet?
Thanks,
Mike
yade wrote:Just so I don't get screwed by Orange's inability to get updates out, anyone know how to change the product code yet?
Thanks,
Mike
Hi, from what i have read the only way to debrand a n8 is to flash with phoenix 2010, NSS nor jaf cant change the n8's product code.
Biggzy wrote:Hi, from what i have read the only way to debrand a n8 is to flash with phoenix 2010, NSS nor jaf cant change the n8's product code.
Oh knickers! :banghead:
...I've not tried it (yet 😉) but this link seems to suggest flashing a Symbian^3 (inc. the N8)phone is possible with Nemesis Service Suite http://nokia.nigelcoldwell.co.uk/firmware.htm. Having said that I would normally believe what Biggyz says, he usually know his stuff ! :icon14:
It also list the product codes for the N8 (for a full list see N8Owner's post here http://www.allaboutsymbian.com/forum//forum/thread/97016/)
...I've not found confirmation that the N8 has been 'Vanilla-ised' yet, but I haven't looked too far yet 🙄. Who's gonna be the first trailblazer on here then 😛cguru::dontknow:
evilweasel wrote:...I've not tried it (yet 😉) but this link seems to suggest flashing a Symbian^3 (inc. the N8)phone is possible with Nemesis Service Suite http://nokia.nigelcoldwell.co.uk/firmware.htm. Having said that I would normally believe what Biggyz says, he usually know his stuff ! :icon14:
The top method doesn't work, I have tried.
I have done the second and it works using Phoenix. :tongue:
I am not saying the product code changes. I can't remember if it did or not as I initally applied generic Euro firmware and it worked and then returned it to my network specific version so I could use BBC iPlayer and their Skype client.
What I am saying is that flash it with any regional version you want and it works but I can't tell you 100% that the product code will change.
Even tho phoenix can flash the N8 it will not change the product code, during flashing it states product code changed, but after a check it didnt change, nor trying to do it manually via phoenix will change it, so at the mo there is no way to change it as far as i know, so all the people that want to debrand need to flash with phoenix.
I'm just gonna sticky this post for a bit... as Im sure theres going to be a few rounds of these questions 😉
I got mine from Tesco. Although there weren't many Tesco loaded features, I thought of flashing a proper firmware from Nokia and tried to do it with phoenix. I have only used JAF previously and when I started flashing the phone, phoenix said some files were missing and if it was OK to continue. I clicked yes and flashing started and the phone died. I had to contact Tesco and they replaced it! So, phoenix is not always successful I guess!
maalicious wrote:I got mine from Tesco. Although there weren't many Tesco loaded features, I thought of flashing a proper firmware from Nokia and tried to do it with phoenix. I have only used JAF previously and when I started flashing the phone, phoenix said some files were missing and if it was OK to continue. I clicked yes and flashing started and the phone died. I had to contact Tesco and they replaced it! So, phoenix is not always successful I guess!
you should have flashed it in dead mode - works like a charm 😃
kpblxa wrote:you should have flashed it in dead mode - works like a charm 😃
was the phone wasn't even recognised as a device by windows.
It was really really dead.
You could long press the power button to reset it .. Phoenix would see the phone for a fraction of a second and then it was gone again.
I haven't found a decent guide to "dead mode" .. I'd appreciate any insight or pointers to online info you might have.
Cheers
I got mine from Tesco. Although many functions Tesco tax, I thought of flashing the firmware from Nokia is a fair and try to do with Phoenix. I've only used JAF already started to flash when I call, Phoenix was missing some files and asked if it was good to go. I click yes and start blinking and the phone is deceased. I contacted Tesco and they changed it! So Phoenix is not always successful, I think.
Have a tesco N8 product code 059C951.
Needed a distraction form the work i was meant to be doing so decided to try and force the update on to my N8.
Downloaded Pheonix and went through teh following guide http://www.nokiausers.net/forum/nokia-n8/39124-so-you-want-clean-factory-fresh-n8-heres-how.html
Bricked it first time. Was not using the correct Pheonix version, then unbricked it once i used the right version and now have a tesco 059C951 with 013.016 working just great. Ovi store is there but wants to update it self to a 2.00.10025 and is failing to that, but that seems pretty normal flaky Ovi store behavior then anything more sinister.
I've not tried to use this process, but so far my Orange N8 seems to be getting updates as soon as they are announced, in the UK. This unit seems to be the least Orangified I've had since my old 9500.
I can also confirm that flashing with pheonix/navifirm works and also that it indeed does not change the product code.
Guys how can change E7 product code ?
Nemesis , JAF and Pheonix didnt work !
Any other program to change or any one did ?
qucuqum wrote:Guys how can change E7 product code ?
.. you won't change the product code .. just use phoenix to install a different firmware onto your device.
by using Navifirm you can find and download the files required for the region/language of your choice (if available)
I just checked and the E7 is listed though no PR2.0 files are available as yet.
It is a relatively straight forward process to use phoenix to upload the new firmware - in my experience its best not to have other devices plugged in to your USB ports while doing it.
Good Luck!
I dont want to instll TR firmware becouse next time when upgrade my mobile that time it will turn to again english lang, you know it chech just product code for new firmware ...
Just ı want to change my product code to TR lang 😊 but ı cant find any program :S if you know one sol please share
Many thanks...
sory my Eng if ı did mistake 😊
Is there any way to install a new language without changing my product code? I wanna add italian!
warmth wrote:Is there any way to install a new language without changing my product code? I wanna add italian!
you'll need Navifirm and Phoenix .. it won't change your product code .. just install Italian (a european firmware with Italian in the language set)
I checked on Navifirm its euro1 ..
Good Luck!
Excellent post. I was checking constantly this blog and I�m impressed! Very useful information particularly the last part
seki wrote:.. you won't change the product code .. just use phoenix to install a different firmware onto your device.
Good Luck!
I agree with these idea, should use phenix to upload the new firmware
All about cycling shirts cheap jerseys wholesale
You'll find when you purchase your road bike jersey, that it fits longer at the back, to hold the weather out as you curve forward across the bars.
There's a whole load of fabrics to pick from and they all carry out a slightly contrasting job, yet one aspect they all aim to accomplish is to wick moisture away from the body.Which one performs this action the best is up for consideration.
Wool cycling shirts are back in favor, as is all things with a retro feel and the sizable advantage of wool is the truth that the top stays fresher for longer, meaning fewer washes which can be a difficulty when laundering particular wool fabrics.You can at times get 10 rides in before they require suitably washing, merely hang them after wearing and they're good to go once more. Cheap Jerseys On Sale
Nevertheless, the sort of knit is developing all the time and you could now find wool cycling shirts that can be machine washed, then tumble dryed on a cool temperature.
Most jerseys come with 1/2 or full zip for fresh air and cool down effect and nearly all have 3 elasticated opening pockets on the back.This is the most comfortable position to carry extras and additionally it allows you access to anything you require without getting off your bike.You may store your mobile in here, eats to keep you fueled up, route directions, waterproof and a bit of money for your luncheon stop.
That should fill you in on a few hopefully useful bits of info on cycling shirts, now it's down to you to find one that expresses your personality to the full and really makes you stand out next time you're out with a number of riders.
