6600 Data Transfer help
2 replies · 7,257 views · Started 06 November 2010
Is there anyway i can transfer the data (sms's only) from Nokia 6600 to Nokia 5610 ???
I have the Nokia 6600 data backup on my pc. i want to transfer that on my nokia 5610 fone?
Is that possible???
if not, any alternate way of doing it???
Thanks in advance,
rajiv...
Which 6600?
The original Nokia 6600, or the Nokia 6600 slide or the Nokia 6600 fold?
With the newer slide/fold models, and a newer Nokia PC Suite, you can take a backup and then restore on a newer phone.
With the original Nokia 6600, you can't (as it is not supported by the newer PC Suite versions which can do that).
