N8...HDMI not outputting
5 replies · 6,152 views · Started 09 November 2010
hi all..i tried connecting my 2 lcd tvs with nokia hdmi adapter..i am neither getting sound nor images...is there any setting in the phone to be done?..i am just taking out hdmi cable out of my video player and connecting it to adapter on the phone..switch my lcd to HDMI mode..it just says searching for signal..nthing happens then,,,any advise:con?
dheerpat wrote:hi all..i tried connecting my 2 lcd tvs with nokia hdmi adapter..i am neither getting sound nor images...is there any setting in the phone to be done?..i am just taking out hdmi cable out of my video player and connecting it to adapter on the phone..switch my lcd to HDMI mode..it just says searching for signal..nthing happens then,,,any advise:con?
Your TV could have a "Handshaking" problem with the N8, try turning TV off, plug in N8 then turn TV on and select the correct HDMI input, also make sure all connections are tight and secure.
THAT DID IT..seems i was babying my new handset..the phone end was not secured properly...took courage to insert it hard 😉
thanx...
hdmi works, fm tranmiter works, now only usb otg to be tested,,,:icon14:
nice phone ..small screen size though and occsional restarts...3.7 and a higg res would have done it
..feels nostalgic to be back at symbian after a long gap...from windows to samsungs to android...
dheerpat wrote:also make sure all connections are tight and secure.
thanx...
Glad to see you got it working mate 😃
Hi dheerpat
Good to hear that you managed to get your hdmi working, and really pleased to see that you're back with Symbian.
Could you possibly post a few comments about how you are finding Symbian please? I'd like to understand what differences you've noticed, what you're still missing from Android, Windows, what you're liking etc? I don't mean to open up "old wounds" or anything... but with the ongoing criticisms of Symbian, and the apparent popular appeal of Android it would be good to hear from someone who can comment from experience.
