I quess the subject already says it all. How can I read my textmessages/SMS on PC? Is it possible through the PC Suite made backups or how? Or is there program for this problem?
How can I read my textmessages/SMS on my PC?
Search the forum. Your answer is already there.
Ah, but has anyone come up with a way to edit SMSs from your PC, or to move a draft SMS to My Folders?
To type SMS from your computer, I know about Remote S60, but I've given up on getting it to work reliably with my bluetooth, as I've only ever gotten it work after repeatedly trying over and over again. I only manage to get it to connect accidentally every now and then.
What I'm looking for is a way to type an SMS, but store it in My Folders without sending it.
At the moment, the only workaround I've found is to type an SMS, send it to someone, and move it from Sent to a Folder.
Anyone have any ideas?
[quote="Herra kuusysi"]I quess the subject already says it all. How can I read my textmessages/SMS on PC? Is it possible through the PC Suite made backups or how? Or is there program for this problem?[/quote]
Use Message Saver http://koti.phnet.fi/jarilaak/software/msgsaver.html
you can send all your e-mail, MMS and SMS to the PC using BT or infrared as a text file
