When i play mpeg files from pc i only c them in small window!!Record video from hantro..again small window...Why''''..????I have the 1.34 version.Thanks
Real player replay in small window only?!
Yes - bit of a pain that - thats because Real is playing the file at its actual resolution which is the 3gp standard resolution - it has options for 'scaling' in realone but that only scales down big vids and does not scale up to fit the player window - when you send an mpeg to the phone Pc Suite will convert it to .3gp and again, scale down the resolution to the 3gp standard - so even if the vid started off high res, it will be scaled down.
I'm kind of hoping this will be resolved in the next firmware update if it's not already on 3.50 and the scaling option in Real with scale UP as well as DOWN.
The alternative if you have .mpegs on your PC is to encode them first using real producer8 as real videos at the correct resolution to fill the screen then send them to the phone, PcSuite will not try to convert them and they will play at full size - real does a better job of encoding too.
Best 😊
Will
