im having problems backing up contacts. i have trie microsoft outlook with no luck have tried lotus notes with no luck wich are both required for backing up with 7650 pc suite. is there any other software that i can use to back up my phone please
thanks
any other software to backup contacts
What problems are you having with Outlook Synchronising?
I guess you are using PCSuite, if you backup your phone with PCSuite the contacts database is backed up with it.
Give a few more details and some people on this forum may be able to help solve your problems.
Bob
ok as soon as pc suite ties to open outlook for sync it crashes pc and restarts pc.
when i try to use lotus notes pc suite says it cannot find lotus.
That is the first time I have come accross such a serious Outlook crashing problem.
If you start Outlook before starting PCSuite, what happens?
Bob
Is this a problem with backing up contacts or synchronising them?
Because the normal PC-Suite backup up function backs them up, and you get the option to restore just them if youlose them or delete a contact by mistake.
