How do I change the background color on the N8, from black to white with black font.
I have tried to change the theme bit it dosent make any difference?
Colours are theme controlled so you'd need to find a theme that had a white background however you probably don't want black on white (unless you have a pressing need):
You could try this "Pure White" theme from Pizero,,, it's FREE. 😃
JayTay is correct though when he states that it would be a bigger drain on your battery,
Having said that, if the theme makes it more legible for you, then all well and good.
Pure White theme:-
