Stange Sync problem - Any ideas ?
4 replies · 2,222 views · Started 26 March 2003
Hi All.
Just replaced my Jornada 928 with a P800. Love the phone.
Installed sync prog off CD on Win2Kpro (sevice pack1), connected P800. Everything synced except for the Calendar from Outlook 2000, yet it reported that it had done all syncing.
Have tried installing PCSuiteForP800_rel_1.3.1_EN.exe (which by the way installed ok) but still no joy.
If I tell the others not to sync but only sync calendar, it gets as far as initialising and just sits there doing nothing.
I've tried using default calander folder, manually selecting it and copying it to a new folder with no joy.
Any help would be gratefully received.
Thanks,
Nigel.
To asnwer my own question :
SE Tech / Data suppport state that according to the Knowledge base this is a know problem with no known fix.
They suggest I install PCSuiteForP800_rel_1.3.1_AE.exe instead of the _EN_ version I tried earlier.
Will keep you posted.
Sorry if this has been discussed before. I did look back through the forum postings and could not see this mentioned previously.
Nigel.
I had the same problem with Win 2k Service Pack 2 (and also Win XP Home). Strangely, on my Win 2k office PC, after I tried a sync while logged in as administrator, Outlook 2000 calendar managed to sync with my P800 subsequently. Works fine now even logged in as a non-administrator. I have no clue why it worked but I'll just let it be.
I know it's bad form, but I'll answer my question.
Problem syncing Outlook calendar cured by making Outlook the default email program from within IE. Bit of a bind especially as I use Turnpike and not Outlook for all me email.
Called SE tech/data support to advise them that this was the cure to the knowledge base notice saying "no fix available" ,feeling chuffed with myself, only to have my call taken by a different engineer who said, "Yes we know about this fix and I've already explained this to several callers today !"
I suggested that he has their knowledge base updated then so twhen the next person to come across this problem doesn't do like I did and spend hours uninstalling and reinstallling different versions of sync software.
Oh well they're only human 😃
Nigel.
[quote="Legin"]Hi All.
Thanks,
Nigel.[/quote]
I've solved the same problem by renaming with a short name the profile name of outlook. Right click on outlook icon on desktp, profiles and rename your standard profile woth a short name ... good luck
