does any one know how to set the delay time before the lights go off on nokia 3650?
When i am seeing something without using the keys the display light goes off, and its difficult to see in dark. :fadein:
The good lord himself is the only person that knows the answer to that - the rest of us have to make do with a little utility called 'torch'
Best
Will
I will check that appz
[quote="willbrady"]The good lord himself is the only person that knows the answer to that - the rest of us have to make do with a little utility called 'torch'
Best
Will[/quote]
vuw u 😉
With the eProfilesPro from PsiLoc (v1.60 or 1.70) you can choose how your backlight turn off. Options are:
-Normal
-Always on
-On if charging
So you can modify a profile for reading where backlight is always on 😊
