which one is better? spacedoubler or stacker?
what are the good points of spacedoubler?
what about stacker?
i have both... and have installled spacedoubler but it can only zip certain files...
can stacker do more?
can i install both?
SpaceDoubler or Stacker
stacker is better,but i use both of them, try to install stacker and sDoubler 😃
sorry... forgot to login
is it really possible to install both stacker n spacedoubler? will both of them clash?
For me Stacker is better
four compression levels
what about stacker?
1. Stable - never give me even a single error since day 1
2. Customizing
I'm using Stacker to compress my videos, tones, sound clips that are not in use, images, games and applications that are installed in the phones memory and MMC... all was compressed properly.
what type of files do you want to compress?
can i install both?
Some users installed both but I dont because Space doubler gives me error.
my opinion, if you using 3650 you don't need to use stacker or sDoubler it's useless,coz there is MMC 😉 im using 128 MMC,so for it's useless to use both app 😊
i know.. but i dont know why my phone memory is decreasing day by day.. see this
831kb - Calendar
189kb - Contacts
180kb - Documents
5kb - messages
47kb - images
1kb - sound files
0 - video
0 - applications
3346kb - memory in use
747kb - free memory
i dont know why so much memory is used by the calendar when i have not touched it before.... contacts... i dont know how to move them to mmc card ... documents... i dont know what documents are they.. so i cant delete them.. messages... are stored in my mmc.. but still it says 5kb is used... so i m trying to decrease my phone memory.. very tough job though... can anyone help?
[quote="smashpOp"]i know.. but i dont know why my phone memory is decreasing day by day.. see this
(1)831kb - Calendar
(2)189kb - Contacts
(3)180kb - Documents
(4)5kb - messages
(5)47kb - images
(6)1kb - sound files
0 - video
0 - applications
(7)3346kb - memory in use
(8)747kb - free memory
quote]
to 2. its a good question. if anybody nows how, tell me
to 1. no idea
to 3. its the help files. u cant delete them.
to 4. change the folder again to internal memory and look that u dont forget to delte the old ones.
to 5. move ur images to the mmc.
to 6. move the files with a filemanager from internal digital to mmc digital.
the rest i dont know.
cya amigappc
Can one compress a file from apc then send it to 3650 would it work?
