I sent my N8 to Nokia Care a while ago, cause the plastic cover at the top is creaking
Now they sent it back without changing anything.
Here is a link to a little video about the issue: http://www-old.c0br4.de/n8_creaking.avi
Is anybody else suffering from this issue?
Yeah, I too had that issue. By the earpiece, it would creak if lightly pressed.
Also, I found the sound thru the earpiece not to be very clear compared to my N79.
Still, I had to send it back due to the power down problem.
If I get an exchange unit, I'll let you know if there's a difference.
edit : Looking at your short vid, mine creaks from the front and only the top not the bottom.
Thanks for your Reply!
As I got my N8 back on Thursday I decided to send it back to Nokia Care again, because they told the service technician at my shop that they had removed the creaking noise.
Additionally I wrote Nokia Care a mail concerning this issue.
Now I've to wait again.... 😞 hope they will fix it this time. If not I'm really pi**** off.
mine doesnt seem to be suffering from this...i've pressed/squezed all over the phone without any noticeable noise
