using computer's internet connection on n8
2 replies · 9,113 views · Started 04 December 2010
does anybody know if ip passthrough can be used in nokia n8, if no then is there any other way to access my desktop computer's internet on my nokia n8 without using a wireless router.
i have found an easy way to download ovi app to my pc and then install it to you phone. to do this just go to the ovi site using your computer internet browser, go to the apps section. click on the app you wanna download and then click on send to friend. after this in the address bar replace the words "send to friend" with "download". the file will get downloaded to your system. then transfer it to your mobile and install. have fun.
