I'm completely out of memory on c: but there's nothing on C: according to the built in file browser.
So I try to install Y-Browser but it won't install anything because it's out of memory.
So, what's the name of something that can browse the files on c: from Windows itself?
Otherwise I have to wipe everything and start again!!
Thanks!
If you have a hacked phone, you can install MapDrive v1.01 and set
A=C:\ .
in E:\mapdrives.txt
If it is not hacked, goto settings->application manager (v5) or applications->app. manager (v3) and try removing some programmes via app manager.
Best thing is just to backup messages, emails, notes and contacts using the PC and doing a hard-reset on the phone (*#7380).
Connecting it to the PC with Nokia PC suite ONLY lets you view C:\data.
I'd remove something and install x-plore and prune my C: with that.
Same situation again(3mb left), only this time some git from work has put a password on so I can't format my phone and start again!
No option to override in NSS either...
reformatted... 55mb last week... 40mb free now.
I've got to find where this memory is going to!
