Installation package not found. Check that memory card is inserted.
1 replies · 14,971 views · Started 10 December 2010
when I try and set up email it tells me Information is needed to activate existing mailbox. Needed information varies, depending on email service provider. Answer the following queries. So I press "start" then I get this allow connection message come up which I agree to also, then I get the Connection to server, then a message comes up saying Installation package not found. Check that memory card is inserted.
I know this has been beat to death is there a simple file we can download from somewhere to re set up on our devices???? or memory cards?
I tried the reset of device, *#7370# then entered 12345
same issue i mean i have the google mobile apps loaded with email and all but id like to still use the email that came with he e71
Here is what fixed it for me
When you're asked to connect , press no and configure your e-mailbox manually.
