So how bout a thread on the best must have apps for the N8.
Best to give a little description of the app as well as criticisms!
So here goes:
Nokia Situations: Similar to Psiloc's miniGPS! Allows your phone to adapt depending on the situation at the time. i.e Switch to meeting profile when it detects your work wifi; or change to silent if it connects to a particular mobile cell AND it's sunday for when you're in church 😉
Panorama: Allows you to automatically take panoramic pictures. Truly amazing app and it works really well! Stiching the pictures is automatic and you can hardly spot the stiched points. There's also a guideline and prompts if you move the phone too much on the vertical plane
Coming Next: Calendar widget that displays your upcoming events for the next 30days. It can be setup to take up multiple widget space as well
