Testing my app on S^3 phone
4 replies · 2,873 views · Started 17 December 2010
[SIZE="4"]EDIT: HELP WITH THIS IS NO LONGER NEEDED AS IT IS DEFAULT BEHAVIOUR ON S^3[/SIZE]
[SIZE="1"]Hi,
I was wondering if someone with a Symbian^3 device, wouldn't mind doing me a favour and testing out some of the functionality of an app i wrote and currently have in the Ovi Store for s60 5th edition devices but I want to add for S^3 devices but I don't have one to test on.
The app pauses the default music player when you remove the headphones, this behaviour is not something that I can test using Nokia's RDA devices so I was wondering if someone would be so kind and try it out for me?
As all S^3 devices should work the same, I only need one person to test it,
thanks for your time,
Matt[/SIZE]
Sorry I should have said, if you let me know you are interested, I can send you the sis file for testing as you won't be able to download it from the Ovi Store for S^3 phones as it's only available for s60 5th edition phones. The app is called Pause On Disconnect but that's not important right now 😊
Ah thanks for letting me know, I'll assume it's the same across S^3. I'd read somewhere else that it didn't, I'll edit my original post to say this is no longer needed, thanks for your help.
