Which holder du you recommend for the Nokia N8, I need a new one for my car?
Thanks in advance
Mike
Thanks in advance
Mike
I woud suggest the genuine nokia version
link to ebay:http:
//shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1313&_nkw=genuine+nokia+car+holder+for+n8&_sacat=See-All-Categories
I have 2 and the nokia seems less abrasu=ive when inserting etc
Boothy
I've got the Brodit powered holder ...http://www.dsldevelopments.com/brodit/holder/Nokia+N8-Brodit-Holder.asp which works nicely. Expensive, but a good product which holds the phone snugly, aligns well with the (usb) power connector and leaves all the buttons on the phone accessible.
I've used Brodit mounts in the car for P990, E71, N900 and - now - N8. The common base makes it easy to swap holders at the ball/socket universal joint.
And on the pushbike, I use a (much cheaper!) holder from eBay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160517618926
Simon
I bought one of these because it was cheap.
Halfords cheap and crappy holder
The holder has small plastic teeth which fit onto the vents on one of the heaters. My car has a very convenient placement, which means the phone is below the windscreen but well within reach. It's also quite close to the radio, so the FM transmitter works well from that position.
It holds the phone well but you can't get a USB power source in under the side pads and of course the bottom of the device is completely covered too. The unlock switch is just about accessible on the right hand side as long as you put the sticky pads supplied at the front of the side pads.
I have cut out a small hole in the bottom of mine and fixed a small nokia charger through it, it fits into the bottom of the phone quite nicely. The charger I use came from Argos for about a fiver too, and it's got adaptors for most phone types or anything which can charge from USB. Incidentally, the FM transmitter works OK when the power is on too, which can be an issue with some chargers, especially cheap ones.
It's ok if you're doing it on the cheap. I'm happy with it.
Thank you guys
Cheers
Mike
Another vote for the Brodit mount here!
I'm also using the Brodit Active Tilt/Swivel holder in my Passat, it allows you to have the phone in either portrait or landscape mode without fear of it falling out and as Spooley points out above it picks up power from the USB port without any fiddling. I just unscrewed the N86 holder from the mount kit and replaced it with the N8 version.
The mount kit doesn't seem to damage the dashboard when it clips in around the central vents as it comes with tapered spacers to open the gaps up.
Well worth the money.
I bought this Brodit Active holder mounted on Herbert Richter windscreen mount from Holders and Mounts. Highly recommended. Brodit active mount is excellent.
ive never seen the point in broadit holders to be fair i find them well well overpriced and wouldnt recomend them when you can get products that do the same job for way way less
i really cant see the point in paying nearly �50 for a car holder for a n8 that costs approx 310 pounds from o2 and tesco
there are much cheaper just as suitable alternatives avalible on the market that will cost between 5pounds and 15pounds maximum
this way you could buy 35-45 pounds worth of apps or even have a fund day out somewhere or a dinner out
shop about mate and iam sure youll find some that do a great job for a fraction of the price of a broadit car holder which is a good holder but just well well to exspensive for what it is ---- a mobile phone holder lol
I went with Brodit as I wanted a secure holder that would clip onto the dashboard without damaging anything and wouldn't need to use suction cups and stick on the windscreen. I'd rather pay a little more and get something decent but YMMV.
To me it's worth spending a little extra. In past I spent few pennies buying cheap holders from auction sites and to be honest, they kept on falling off my windscreen. I spend fair bit of my time in my car and this one has an amazing suction mount and it's worth spending little extra on something I'll be using fair amount.
i got a nice one from hong kong on ebay, used the guy b4 for my 5800, also he does a `bike` attachment so i can fix it to my MTB😃...cost less than �5.
234234
