Can the motorola Bluetooth Handsfree be paired with the Nokia 3650?
Thanks.
Thanks.
Does it support the "Bluetooth Handsfree Profile"?
If it supports "Bluetooth Handsfree Profile" it should work. Otherwise, if it only supports the "Bluetooth Headset Profile" it won't work.
It's confusing but unfortunately there are two similar Bluetooth Profiles that don't work together.
-- Max
