x6 lanuguage gone.
3 replies · 19,387 views · Started 25 December 2010
Hi all!
I am new to this forum and I hope someone will be able to help me : )
I have bought an used Nokia X6 and it came with lithuanian (BALTIC language pack i presume from lots of googling). What was strange - i checked product code of the phone and it was for United Kingdom V3. How could it have baltic languages (Lithuanian, Estonia, Latvian) installed without firmware of that kind? As I have read the language packs (currently mine is 01) come only together with firmwares of the same region.
The baltic languages dissappeared from display and writing when I did an update to the phone. As I have read there is no way to revert firmware. What should I do?
I tried to change product code with Nemesis to lithuanian one and then updating with Ovi suite but it stopped in middleway and threw an error. And took way more than it is supposed to (2 hours until error).
I have changed back the product code to the one I found and now have United Kingdom (i presume) version of firmware.
What should I do to get Lithuanian one, and will it brick my phone if i did so?
I'm very confused...
I have fixed it myself. For anyone else aroud here is what you shold do:
Tools needed:
Nemesis Service Suite (google it up)
Nokia OVI Suite (or nokia software updater)
Navifirm v0.3 (google it up too)
What you do is you open up Navifirm and find your phone model on the left, then go through the columns until you get to the next to the last. Find the language you need and write down product code (starts with 0).
Then open up Nemesis (google for a tutorial). Replace product key and check it again with read (OVI must be closed).
Now open up OVI and go to software updates. If there is no update for the phone choose reinstall, it will download the correct ones. Device will restart and everything should be fine.
Hi!
Maybe you can help me to find baltic language product code for my nokia asha 303. In NaviFirm there isn't 303 model :con?
The battery is not as long as possible, no protection circuit of the battery is full of that should stop charging, or battery for heating or overheat impact performance
