My N8 keeps turning off the sensor so i cant switch between horisontal and vertical view. At the same time my gps settings are turned off. i have tried sw update and reset to factory settins but it diddent help. any suggestions??
fixed it. it was the "Battery Extender Lite" app that was the problem. it was set to max battery, and that kept turning the gps and sensor off.
