Messaging app
2 replies · 2,870 views · Started 06 January 2011
Is there a way to put the messaging application on a home screen?
I have the widget thing with address book web and so on but the message bit just creates a new message and will not let me navigate to my sms inbox which is what I want to do.
I know I can press the menu button then go to messaging. my n95 has it I figured I could do it here too hopefully I am missing something basic.
if you options...edit home screen...select shortcuts as a widget and then it gives you the option to select 4 widgets. scroll down till you get messaging
Thanks for that. I selected settings on the widget thing and applications then found messaging.
Superb. I am grateful for your help.
