Hello,
i need your help!!
My P800 hangs up when i start calendar or contacts with message:
i.e:
Program closed, Program Calandar, Reason code ViewSrv, Reason number 11
after a master reset it works for a while then the message came up again.
Thank you for your help!!
ViewSrv 11 is a time-out error. The application (Calendar in this case) is taking too long to start, so it crashes. You could try fixing it by removing the files c:\system\apps\agenda/agenda.ini and c:\documents\agenda\agenda (file with no extension) using the FileMan app. This will make you loose all entries in the Calendar (a.k.a Agenda) application, but it might help you.
Hi, I had the same problem.
It comes after trying to download a song (hours after).
I don't know why, but it was because of receiving ring via push messaging.
I deleted them with the explorer (web) And it is yet okay. I can access my calendar again.
Don't hasitate to contact me again.
Philippe
www.philservices.ch
