3650 for dummies
9 replies · 2,513 views · Started 27 March 2003
Hi! I have just got my 3650. Beautifull! Work�s fine. What i wonder is: 1: where do i find some cool applicaitons/games for it (a smal description of each is helpfull...)
2: mp3go, have you tried it? how does it work? where to get it (i live in sweden)
Thanx a lot!
forget mp3's...
if you install the pc suite, than select the mp3 on your pc and sent it to your 3650, the pc will convert the mp3 to wav, but the size is smaller than the mp3 and the sound is great
greetzzz
well if you place the mp3's on your mmc (cardreader or bluetooth) set your options in pc suite not to convert mp3 format
sound is quite good if you have headphones like the dual hdd 1 earphones of nokia or bluetooth
what is the right folder that i can put wav files into and listen to them without having to go to the ringtone menu?
also i have converted a number of music video clip using real producer plus but none of them are able to be played. I am able to play the clips that i downloaded that someone else converted but mine won't play.
i have changed the video codes to real player 8 but is that ok?
wat other settings do i need to have right so that it will play?
ah so we can listen 2 mp3s fully on the phone then, i aint got a right an answer for tht yet!! lol :P
This trick for storing mgs games in mmc is very wanted.I also saw it in the 3650 forum but now its down!Please if somenone knows...thanks
