sorry but i may be posting this tread in the wrong section but i have now migrated from a N95 to a N8. Does anyone know of a way to be able to access the N95 rom to be able to access the ringtones. I would like to use some of the old ones i had that are not available on the N8?
nokia n95 ringtones
jonti wrote:sorry but i may be posting this tread in the wrong section but i have now migrated from a N95 to a N8. Does anyone know of a way to be able to access the N95 rom to be able to access the ringtones. I would like to use some of the old ones i had that are not available on the N8?
I did the same for my N97. You won't need to access the N95 rom, the N95 ringtones are easily found on the web...or at least they used to be.
Will look around now but if no luck I'll upload them when I get home later.
matthewrleech wrote:Will look around now but if no luck I'll upload them when I get home later.
Here you go.
Thanks so much matthewrleech. what a quick response! really appreciated,:icon14:
