my nokia c7 has switched off and it is no
5 replies · 4,135 views · Started 18 January 2011
hi,
i bought nokia c7 two weeks ago now i am facing a problem that
my nokia c7 has switched off and it is not onning
i dont know what to do on this matter tried battery change but it wont work any help on this matter please
connect it to a pc ..
if the pc does NOT recognise it at all then you'll need a repair/replacement.
if it does recognise it then you may be able to reflash the firmware.
the best course of action is take it to a Nokia Care Center .. Good Luck!
I had a similar prob to this with the N8 where it just looked like it was dead... have you left the battery go completely flat?
I had to leave mine on charge for 30mins before I saw any signs of life at all... seemed ok after that tho
seki wrote:connect it to a pc ..
how do i reflash the firmware pls guide me on this
zappernator wrote:hi,
My friend is also facing the same error and as far as i know it is built in fault.
I took my bd to the vet 3 days ago, because she wouldnt put on weight. The blood tests came back today. She has something wrong with the way she takes in protein and fat. I think it might be hereditary
