It seems to me the favorite contacts (the starred ones) stay with the order they were added... Is there any way of changing the order of favorite contacts?
Thanks,
Miguel
Thanks,
Miguel
mcduarte2000 wrote:Hi,It seems to me the favorite contacts (the starred ones) stay with the order they were added... Is there any way of changing the order of favorite contacts?
Thanks,
Miguel
My short and pithy answer is sync with Ovi Contacts, that'll screw the order royally. Other than that, yes, it does keep them in the order you added them, so add your best mates first.
Regards
Neil
Ah! 😊 Good the first one to be stared was my wife! 😉 And I sync my contacts using Mail for Exchange, which doesn't have the problem you just described (actually it works great!).
But this is a bit of stupid feature limitation, sure the drag & drop of starred contacts wouldn't be very difficult. :P
