i just got my satio a few months ago and evrything has been working perfectly until a couple of days ago. my satio suddenly cant connect to wifi and i have no idea why. every time i try and connect to i get the msg "wifi network not found. could not connect"
can anyone help me???
satio wifi problems
update the patch to have your game saved by its save replay option. then u can view it by clicking load replay on the "campaign" screen. u can also explore ur replay by finding it on starcraft folder.update the patch to have your game saved by its save replay option. then u can view it by clicking load replay on the "campaign" screen. u can also explore ur replay by finding it on starcraft folder.
pokey.egg wrote:i just got my satio a few months ago and evrything has been working perfectly until a couple of days ago. my satio suddenly cant connect to wifi and i have no idea why. every time i try and connect to i get the msg "wifi network not found. could not connect"
it is looking for a specific wifi ssid .. and not finding it.
what happens if you try browsing for wlans ?? (this supposes that your wifi router's ssid isn't "hidden"😉
is your wifi router still using the same ssid? has the name changed or some other security options.
I'm sorry I don't have a Satio any longer but HTH.
If there are better symbian, we can still try it out.
