Failure of updates and social widget
0 replies · 3,624 views · Started 24 January 2011
I'm not sure whether this tread is out there already. I am very sorry if I make a second one as I couldn't find one through the search button.
My problem would be, well, the updates doesn't install. My phone able to detect all the new updates but it doesn't install. I Factory reset it already but still the same.
As for the social apps.... the widget does not work. but the apps works fine.... only no widget....
Need help....
Thank you
