MMS voice clips dont send
6 replies · 2,893 views · Started 28 March 2003
Put my chip into off line 3650 and l cant send voice only pics tried different networks help
Hhhmm I can send sound clips via MMS without a problem.
If you can send images or videos via MMS.. you should be able to send sound clips too..
Any other error message? If the only error is "failed".. that is a netwrok issue (I think). it could be the recipient mobile is off that is why failed to send or the recipient is out of reach.
Try again :angel:
I am using an o2 and T mobile prepaid chip l can recieve mms from another phone and send it via blue tooth and infrared someone said the prepaid networks dont support realone what network are u on
I'm not on 02 or T-mobile . dunno what these 2 network support or dont support. Have you tried asking the customer service of these 2 networks if what you heard from someone is true?
[quote="Mike"]I am using an o2 and T mobile prepaid chip l can recieve mms from another phone and send it via blue tooth and infrared someone said the prepaid networks dont support realone what network are u on[/quote]
Hi.
That is only for steaming video/audio live over the internet, thou Real are saysng they have a fix for this.. Not sure what the fix is yet.
Sending files by MMS is not the same.
Thou as far as I know, T-mobile can MMS into the orange & O2 network, but not the other way, orange & O2 are not able to MMS into T-mobile.
And Vodafone can only MMS to other Vodafone.
This situation will be changing shortly and cross network MMS should be avalible in the next couple of months.
Best
Will
Hi mate the thing is the other phones recieve my picture mms just not the voice recording with it customer service say the phone is not out on their network yet l can receive mMs with voice clips but cant compose my i think l should wait until the phones are out on the network
