SD card
12 replies · 2,181 views · Started 28 March 2003
http://www.sandisk.com/consumer/mmc.asp
will this work on the 3650? anyone?
oh yes, if you have a bluetooth headset, can you listen to music trough the headset or not? for example what you recorded?
thanks
greetzzz
Nokia is written there.. that means it will work. The best thing to do is make sure that you tell the store owner that if it will not work, you can return..
dunno about your other Question coz I dont have bluetooth yet :cry:
Series 60 1.0 machines (based on Symbian OS 6.1) like the Nokia 3650 currently only support MMC (MultiMedia Card), not SD (Secure Digital) cards.
SD slots are backwards compatible so that devices that can handle SD usually also accept MMC, but the it is not true the other way around; if a device only supports MMC, it cannot handle SD.
nething beter about SD cards or are MMC just as good cos most of us here are 3650 supporteers
lol
SD has more functionality (can accommodate peripherals throgh SD-IO support, built-in data encryption/decryption mechanisms, larger capacity and faster speed).
MMC is cheaper to produce (& to purchase). Capacity and speed issues will still improve (however, for that, you'll need a new phone if & when such is available).
o ok but speeds cant be unbarely slow on it are they, they must be reasonable? and its good tht they are cheap so i can afford them easier!!:P do 128mb ones work with 3650 ?
128mb mmc works fine.
i have problems now and i have 47mbs installed on the mmc with pictures and mp3s. if i turn off my phone and restart it, it says wstartup error 7 or something like that.
cya amigappc
yup 128mb MMC works fine
i have Ali G the movie (49 megs with suggested settings except 15fps)
about 13 or 14 music video clips (each 2-4 megs in size)
5 or 6 mp3's converted to wav format
60-70 images
50-60 midis
and a few recorded videos
all this takes up 93mb
sure, its rm
bit rate: 80kbs
frame rate: 15fps
voice codec: 16kbs
music codec: 8kbs
size: 176X96 (i wanted to keep the ratio)
As i said in other post, picture quality is pretty good but the sound doesn't seem all that good. I don't know whether this is because of the settings or not.
