Hi
Is there a way to type short info/text using Nokia N95 and password lock it ? can u lock the text in Notes ? could anyone help? thanx!
Hi
I took my bd to the vet 3 days ago, because she wouldnt put on weight. The blood tests came back today. She has something wrong with the way she takes in protein and fat. I think it might be hereditary
The Notes Application in the Symbian OS is somewhere hidden in the device memory C: . Probably in the Private Folder . The only two things you can do is generate a Note or delete it .
Step 1 : When you like to store unseen/hidden notes , there is the option of installing a third party Text editor like QuickOffice (paid) or DEdit (free) use Symbian 9 (=S60) 125kb 0.76 R12 : http://jbak.ru/dedit_en.php , or Lightnotepad (small text only) : http://www.petnetti.net/lightnotepad/indexE.shtml
These Apps create files you can store on device memory C: or memorycard E: .
Step 2 : Install a third party Filemanager that can hide any file you wish . Example Y-Browser (in OVI Store) or X-Plore (free , non-stopping trial) : http://www.lonelycatgames.com/?app=xplore .
It is some work and has a learning curve . But after all it will be easy to hide any created (text) file .
😊 Regards jApi NL
