hi guys, does nokia 5230 supports jar format. . If so . . My nokia 5230 is not supporting dat format. . I always get error msgs like file cannot be opened . . Unsupported format. . While i try to install some games. . Even i also tried after formatted my mobile. . Still the problem persist. . Need ur help. Desperately . . Thanx in advance
jar format issue
Yes, the 5230 supports "jar format" (meaning that it supports Java Micro Edition, JME, applications, or so called MIDlets).
All .jar files do not containt MIDlets, but they could be Java Standard Edition, JSE, applets intended for PCs.
And if it is a MIDlet, it might still not work, if it is made for an incompatible version of Java than what the phone you have supports.
The 5230 supports the following Java technologies:
JSR 139 Connected, Limited Device Configuration (CLDC) 1.1
JSR 118 MIDP 2.1
JSR 248 Mobile Service Architecture Subset for CLDC
JSR 75 FileConnection and PIM API 1.0
JSR 82 Java™ APIs for Bluetooth 1.1
JSR 172 J2ME™ Web Services Specification 1.0 (RPC package)
JSR 172 J2ME™ Web Services Specification 1.0 (XML Parser package)
JSR 177 Security and Trust Services API for J2ME™ 1.0 (SATSA-CRYPTO package)
JSR 177 Security and Trust Services API for J2ME™ 1.0 (SATSA-PKI package)
JSR 179 Location API for J2ME™ 1.0
JSR 184 Mobile 3D Graphics API for J2ME™ 1.1
JSR 205 Wireless Messaging API 2.0
JSR 226 Scalable 2D Vector Graphics API for J2ME™ 1.1
JSR 234 Advanced Multimedia Supplements 1.1 (audio3d)
JSR 234 Advanced Multimedia Supplements 1.1 (music)
JSR 256 Mobile Sensor API
IAP Info API 1.0
eSWT UI API 1.0.3
Nokia UI API 1.2
JSR 135 Mobile Media API 1.2
