Save Youtube Video to Symbian ^3 ( N8, C7, C6-01)
4 replies · 78,332 views · Started 01 February 2011
How To Download And Save Youtube Videos to Symbian ^3 (N8, C7-00, C6-01) Mobile Phones.
For that you will need UC Browser from www.uc.cn and your native web browser or Youtube app from m.google.com
Youtube app is optional, native web browser works just as well. I will show you how to use native browser as well as Youtube app.
I tried different web browsers and different video downloading sites but all the other sites required the use of Java Downloader9 and none of the symbian web browsers I tried supported that. Tubezen.com was the only one that seemed to work without the downloader but it didn�t work well with other web browsers. Until I tried UC Browser�
1. Open the Youtube app and find the video you�d like to download and save onto the phone.
Next click Menu � Copy video link
2. Now open UC Browser.
I was using C6-01 so didn�t have much internal storage memory and that�s why I changed the save location to my SD card (E:\ drive).
In order to do that (or just confirm the save location) click on the middle button on the bottom Menu bar.
Then click Settings � Preferences � Download Settings and select your storage location.
3. Go to www.tubezen.com
Double click on the green bar (on top of the download button)
If your screen is missing the green download bar, scroll down and click where it says Standard (Pc Version)
Check the next replies for the rest of the instructions.
Chengo
In the keyboard click middle button on the Menu bar and select paste.
Link will be copied and confirm with green tick in the corner.
Press download, scroll down a bit and screenshot of the video is displayed.
Under the video screenshot different file formats are available.
Select MP4 (I tried to download MP4 HD 720p, but it didn�t work � then I checked the webpage with PC and same problem. Only MP4 and FLV formats seem to be supported).
New window opens.
Scroll down a bit. Where it says Selected Download format MP4 should have a blue Download button underneath it.
If it is missing (and in my case it was missing every time), press the middle button on the bottom Menu bar and select Refresh.
Now it says Process completed and blue Download button is available.
Click on it and you must decide what to do with the file. Select Save and Downloading begins.
Click on the downloaded file, select Open File and it opens in native video player.
That�s it. Now the Youtube video has been downloaded and saved onto your Symbian ^3 phone.
Next I'll show you how to use native web browser instead of Youtube app.
Chengo
As mentioned earlier, Youtube app is optional and the video selection can be accomplished with the native web browser.
First select your video.
Now click the middle button on the Menu bar.
Double click on the link and text editor opens.
Select all text and press (you guessed it😃) the middle button on the Menu bar and select Copy.
Now go back to UC Browser, paste the link to Tubezen.com and follow the rest of the instructions.
I spent good 3 hours on finding the solution and since there was nothing else documented on the web, I thought I�d save you some time.
Chengo
Keepvid says "Loading Java applet" and never shows the download links in my C6-01 web browsers.
Also just found out that you don't really need UC Browser. The same can be accomplished using ONLY your native web browser.
Important is to switch Tubezen.com to Standard (Pc Version).
So long story short:
1. Use native web browser to select YouTube video,
2. Copy the URL link,
3. Open up Tubezen.com in Standard (Pc Version) view,
3. Paste the URL link to green download bar, press Download and follow the instructions on the web page.
But still I like the UC Browser page layout better, with native web browser the web page gets overly big and difficult to manoeuvre.
