3650 Cam lense
11 replies · 3,081 views · Started 28 March 2003
Hi this may have been mention and asked about b4, but as you all probably knw the 7650 camera lense was covered by the bottom halve of the phone while not in use which means while in a bag or pocket or something it was protected, will the lense of the 3650 not get damaged scrachthed or nething in a pocket or bag or something?? and also what meeasures hav nokia taken 2 prevent this or at lest help it?
The measure taken by Nokia is this little device http//www.nokia.com/nokia/0,5184,5809,00.html wink
^ not really. that just means u break the addon lens rather than the normal lens first.
the only REAL way is to get a clear cover or a cover with protective lens. i hear they are available and reasonably priced.
[quote="N/A"]The measure taken by Nokia is this little device: http://www.nokia.com/nokia/0,5184,5809,00.html 😉[/quote]
Is anyone selling this yet? In the UK I mean :P
It would not be hard for someone to make a back cover with intragal slide which slides up to cover the lens and protect it when not in use.
Would not add much to the thickness..
[quote="willbrady"]Would not add much to the thickness..[/quote]
I suppose you could always use a condom :rofl:
Hello!
I can tell you that the add-on lens is not that thick, i would say it makes the phone 3-4 mm�s thicker. There are two lenses in it and in one position there is no lens but the lens is better protected than without the whole thing.
But the lens itself should be very scratch-resistant and i cannot imagine that nokia will release a phone with an "open" camera without having tested this...
Greetings from Hannover
This Nokia Add-on lens CC-49 is bundled with Carrying Pouch (and a Cleaning Tissue- heh!).
They should bundle it with our Nokia 3650.. the box of Nokia 3650 is thick and big enough to put these 3 items in :evil:
They mean business :cry:
