E90 Baterry problem after update soft via Ovi Suite
2 replies · 10,216 views · Started 05 February 2011
I've got the problem with my e90. I install PC Suite and make a update of my nokia e90 (from UK, I think). Everything was ok, baterry was fantastic. It works 4-5 days if I used it normal (some sms, calling, few times with WIFI and GPS). All was great.
Few days ago I want to install Ovi maps, so I install Ovi suite on my PC. I transfer maps to my nokia. Also I make a update. And after that...my problem was started...
Battery keep 1 day, max. 2 days. I used nokia the same like before ovi fail update. Maybe I used it less than before...
Do you hear about problem like this?
Now, I've got soft:
400.34.93
(21.04.2009)
RA-6
Nokia E90 (15)
My statistics in Nokia Energy Profile:
(2 results in the same test in 2 example period time)
TIMESTAMP: 4.208,
POWER: 0.564,
CURENT: 0.146,
VOLTAGE: 3.865,
TEMP: 30.6
TIMESTAMP: 470.446,
POWER: 0.484,
CURENT: 0.125,
VOLTAGE: 3.873,
TEMP: 30.8
Do you have the same result or similar? Let me know, please.
As far as I know OVI Maps are not supposed to be working on E90 : not compatible . So I am interested : does it work for you ? Which version do you use ?
It might be provoking the battery issue . It's also possible that the battery comes to end of life . Normally about after two years .
Do you have Nokia E90-15 ? . Where is it sold ? I only remember versions E90-1 and E90-2 .
😊 Regards jApi NL
If I want to check software I pressed: *#0000# and have this info:
"400.34.93
(21.04.2009)
RA-6
Nokia E90 (15)"
My model is propably from UK or US, I've got shortcut buttons in english.
I'm from Poland. On polish nokia website Ovi Suite and soft upgrade to nokia e90 is possible. After when I install Ovi maps I can use it normally. It was Nokia Ovi Suite 3.0.
Check my statistics in Nokia Energy Profile. Some people told me it's too much if it's open only one programme and screen is black.
