Improvements list for symbian ^3 N8
6 replies · 6,880 views · Started 09 February 2011
I am still a fresh user for N8 and wanted to share with you my thoughts for software improvements and challenge you all to add here new features you want to see on the ^3 devices
backspace on top right corner
@ key on the main keyboard
blinking cursor key on writing text space
writig surface scroll able up and down with a simple toutch or toutch gesture
a easyer way to switch trough open pages in the web browser
easyer way to select all text or parts of the text for copy paste action
enter key on bottom right replacing actual backspace key
to be continued
Definately install swype - the keyboard is so much better even if you do not use the swype function (which after practise is really useful)
Boothy
- Pressing menu button sends unpleasant noise in the bh 905 headset
-Launching few apps downloaded from ovi store cause phone menu and interface to freeze for 30-45 seconds
-The charging battery icon is not active and showing movemnts in all menus or programs
-The keyoard should have a @ key in the main view
picture folder uptate is not pleasant and takes minutes to update
- I am unable to install some apps like swype ota or some apps i have installed does not start (palringo for example, projekt or many more)
easier copy paste or select text ( all text as well) in the landscape view
E-mail issue:
Excepting Pop3...All the mail accounts (yahoo, Gmail, Hotmail) allows you to setup a partial download of the message like header +100kb.
I wish that Pop 3 had this feature . Now I can only choose header download or full download.
Please nokia fix this as well in the next update.
Phone:
Phone hangs up when I press the phone on the face skin (cheek).. should use the motion senson to block the inteface after phone number being dialed and gesture of phone movements towards the ear have been made
