all i want out of life is for puzzle bobble to install i have downloaded it from various places and they say u have to rename the zip to jar which sounds very simple but when u rename it and then send it it automatically adds zip on the end and zipman says no data i got it to open it earlier some how but none of the files in it actually install it so what can i do i need this game peeps !!!!!!!!!!!!!!!!
puzzle bobble just wont install
1) rename it in a DOS window
or
2) go to folder option in explorer and unclick "hide extensions for known file types" which will let the .zip show at the end for you to rename as a jar
