HELP URGENT
5 replies · 2,056 views · Started 29 March 2003
Hi mates! I have a problem with my 3650 phone. On my SMS I can't type any message. The 'Abc' on top doesn't show and when I try texting all that appear are numbers. :cry: :cry: :cry: :cry: :cry:
Maybe it is in the number mode?
While you are composing, press the small button with pencil icon at the left then select Alpha Mode
let's see if it will change back to Alpha mode.
Sounds like the wildskins bug - have you just installed wildskins?
Deactive it and then remove it.
NOTE: You MUST deacvtive it first, then remove it.
You should be fine.
If you have alrady removed it then probably you removed it withou deactivating first - re install, active, reboot, deactive, reboot, nake sure it has really deactivated, remove
You should now be fine.
Best 😊
Will
[quote="willbrady"]Sounds like the wildskins bug - have you just installed wildskins?
You should be fine.
Best 😊
Will[/quote]
oh shit!! thanks a lot Will,thanks bro!! your the man!!! 😃 😃 i thought i cannot send SMS to my friends! thanks again bro! 😃 😃
