nokia e51 installation problems
2 replies · 10,713 views · Started 19 February 2011
i cant install or uninstall applications on my nokia e51.if i try to install it says 'file corrupted' if i try to remove applications .it says 'removing failed'
failed'.i even went to my app manager and turned off my online certificate check.still no results.thanx dawesmith
When your phone is a guinine Nokia , so not a Chinese lookalike , you could try the following , since there is probably a corrupted file somewhere in the device , try to locate :
1) remove the memorycard and try again : when this gives the same result : the corruption is in the device .
2) in this case the best is to consider a Vulcan Death Grip or a Hard Reset . See my post here : http://www.allaboutsymbian.com/forum//forum/thread/81021/ or http://my-symbian.com/s60/faq/showquestion.php?faq=4&fldAuto=29
: ) Regards jApi NL
