i have 9210i and 7650, can i use 7650 as a modem so i can connect to the net thru gprs? 😃
7650 as modem for 9210i
Interesting question 😃 As far as I can see the WWW-settings in 9210 do not recognize ir as a way to connect to the internet. If they did, it might be possible... 😃
Well, let the pros answer 😉
I think i read somewhere yout need an app called 'extended internet' or something similar.
Yes you can, Using Extended Internet .
Good luck 😉
got the trial version...
care for a tutorial? 😃 i cant make it sync or i cant make it connect to the net... 😃
