Hey guys,
Is there away to remove Speed dial #1 as the voicemail? The cassette logo in the Speed dial is very annoying!
Regards
Hey guys,
Regards
Christmas Day!!!! 😃
:roll:
What a waste of two perfectly good posts..
The simple answer to your question, Jams, is no
(or: not at the moment, not easily, or not publicly known)
Well, not as far as I know, anyway.
Every single Nokia that I've ever heard of since the 2110 onwards used the '1' key as a shortcut for voicemail.
You can get around it by assigning another number as the 'voicemail' number, but you can't change the '1' shortcut like other shortcuts (from the 'speed-dials' menu, nor change the image. A really cool bit of programming from J2k is floating in beta-stage that allows you to change default icons, so these things may be possible in future...
