Hi, I've a 7650 Nokia PC Suite installed and running on the PC. I want to use a P800 on the same PC, installing the SE PC Suite.
Is it possible to have both instaleld together on the same PC - or as I fear - would they cause conflicts?
Will be running on XP Pro.
Thanks,
Brian.
Did you ever get anywhere with this?
I am looking to run 9210i and P800 on same machine?
Thanks in advance
i have both Nokia PC suite running with Sony Ericsson P800 suite... it works find and I use Bluetooth(billionton USB) to connect both phone to my PC. It does not clash. But the only back side is that association of *.sis files can be set to one Application only which is either SE or Nokia thus if you associate *.sis with SE for Nokia *.sis installation you need to go into nokia PC suite first before installing the software to the phone(double click the *.sis would runs the SE suite) But it work fine 😃 8)
