Hi guys, anyone knoews how to use. As much as I hid the program, then press ABC + * or Menu, no screen is captured? Is ABC the #2 button? Sorry for the stoopid question...
how to use screentaker?
OPEN THE APPLICATION SCREEN TAKER THEN HIDE IT BY PRESSING THE HANG UP BOTTON ITS LOCATED ABOVE THE c (CANCEL) BOTTON. AFTER HIDING IT THE INTRUCTION SAID PRESS ABC+MENU KEY THE (ABC) KEY IS THE ONE BELOW THE CALL BOTTON THE (gREEN) ONE HOLD IT THE PRESS THE MENU KEY WHICH IS LOCATED ABOVE NUMBER 5 AND 6 BOTTON HOPE THIS HELPS YOU AND REMEMBE TO RENAME THE CAPTURED SCREEN
doesnt work for my 3650 with the built in screenshot in fileexplorer...try the pencil icon as there is no ABC button on 3650 and the space(0) button as instructed...no luck 😞
it works for screentaker though, press pencil icon and menu.... 😊
