how to upload a video to pc?
2 replies · 1,452 views · Started 30 March 2003
i have a prob.how to upload a video from my 7650 to my pc?someone got idea about that..or should i use any software? Thanks 😃
first of all install a file manager to your phone. fexplorer is enough and free 😊
then go to the folder that videos are saved. then get the cursor on to the video that you want to send then press options then send then you see via bluetooth via infrared via etc. choose the one you prefer.
Then after it's in the PC, you need certain software to play the .3gp files (if that's their format) play it using Nokia Multimedia player. Search for that in the forum and you'll find all you need to know about playing .mp4 .3gp 😃
