Jabra wireless headset is it compatible with nokia 7650?
1 replies · 2,074 views · Started 30 March 2003
Jabra advertise FreeSpeak� Wireless Headset and Multi-adapter for Non-Bluetooth Phones but needs an adapter, which one, and does it work?
probably the freespeak for bluetooth phones would not work with the 7650 as it is data only transm the 7650, correct?
if the bluetooth adapter is small and works then one could install a bluetooth car kit also?
[quote="spycorfu"]Jabra advertise FreeSpeak� Wireless Headset and Multi-adapter for Non-Bluetooth Phones but needs an adapter, which one, and does it work?
if the bluetooth adapter is small and works then one could install a bluetooth car kit also?[/quote]
Jabra has a freespeak headset for non BT phones with a nokia 2.5mm adaptor. Make sure you get the Nokia adaptor.
The headset for BT phones only dont work with 7650
The BT adaptor is virtually same size as 7650 so yes should work as a carkit. The charger for the adaptor and headset includes a carlighter charger.
