I hope someone can help me with this problem.
I had 9110 communicator and pc suite for it. And now I installed Pc suite for 9210i v. 2.03(I didn't remove old pc suite)
And after that I tried to sync 9210i with outlook, and pcsuite gave me a error message. It was something like Cannot open outlook. Check your password and try again.
And I didn't even give any password.
I did not experienced something like this, because I had used the DataMover that is in 9210.
May be you should do the same 😉
Or wait for somebody else oppinion on this
[quote="mauzer"]And after that I tried to sync 9210i with outlook, and pcsuite gave me a error message. It was something like Cannot open outlook. [/quote]
Could happen. Try to open Outlook manually before running Sync.
The PC Suite upgrade instructions do say that you should uninstall earlier versions before you install new ones....
i had problem with data mover.finally i logged off my windows 2000 and i log in with another username. the data mover was working fine.maybe it wont work on u,but u should try it.worked at me.
