Not found a post on this so thought I'd mention it
Whilst playing with stacker I found compresssing the contects of the install folder in system to be the only usefull group of files to compress with a good ratio and little risk -just remeber to uncompress before installing anything new.... saved me 40k
[quote="stormuk"]Not found a post on this so thought I'd mention it
Whilst playing with stacker I found compresssing the contects of the install folder in system to be the only usefull group of files to compress with a good ratio and little risk -just remeber to uncompress before installing anything new.... saved me 40k[/quote]
Thanks for the tip.
I did same with Sdoubler and saved 60k 😃
and if you associate the compression with App manager you can install something without first uncompressing as sdoubler does it automatically.
If you do play DONT compress the programs directory!!!
I did and after having to re install everything for some reason stacker didnt work afterwards 😊 still lesson learned!
60k!!! I have 12 files in my directory Im hoping you have more now 😊
[quote="stormuk"]If you do play DONT compress the programs directory!!!
I did and after having to re install everything for some reason stacker didnt work afterwards 😊 still lesson learned! [/quote]
I'm very careful to compress system folders. Funny results at times. Always have backup ready.
[quote="stormuk"] 60k!!! I have 12 files in my directory Im hoping you have more now 😊 [/quote]
Don't worry I have 18 files
so, we're back to square one, which is better stacker or sdoubler??? 😃 😃 hehe just kidding guys!
cheers!
