P800 as a modem under Windwos XP
0 replies · 1,426 views · Started 31 March 2003
Is there anybody who can help to sort out the following:
I tried to install my P800 as a modem using HSCSD or GPRS connection via IR link under Windows XP. Without success! Everytime I connect my phone via IR port the "Standard modem for IR link" will be installed. That's not that bad for now. The problem appears when I start the "Dial-up Networking Wizard". I'm asked to install the "SE P800 IR Modem". But I can't do that on the correct port. There's only the COM1 available because XP is using IR Sockets and occupies COM4 (IR port). Why does the correct IR port not show up in the wizard?
Thanks for your ideas or solutions!
