Defualt location for camera pictures.
2 replies · 2,455 views · Started 31 March 2003
Hi again,
Is there anyway to change the default location that the camera saves just taken pictures (Internal storage/Unfiled) to the memory card.
I know that it is very easy to move from internal to external but if like me this weekend at a show I was happily clicking away and soon found out that I'd run out of memory (640x480/High) so had to stop and transfer them to the memory card.
Thanks for your help.
Nigel.
When you load the Camera App look at what folder is selected (top right). Your will probably say "Unfiled". Select this and choose to "Edit Folders". Create a new folder (on your memory stick). Make sure this is selected. The camera app will use this folder until you change it to something else.
Thanks PonyDerik,
I knew there had to s simply solution.
Shame I was being to simply to spot it. 😮ops:
Nigel.
